GPU initialization detected STUCK, will execute restart script
Is it possible to mix different Riser Versions?
Guys i use the white 008s ones without any problems. I just added another card but had no risers left so i bought some from near. But i bought the 007s version (red ones).
Somehow the OS detects the GPU but miner wont start as error message is: GPU initialization detected STUCK, will execute restart script. Is it Riser issue? Used different ones, always same problem.
