I keep gettings these GPU driver error and the miner shuts down, any suggestions?
you’re on an old image, so i would start by flashing the latest stable image (either via hive-replace or with your pc via balena/rufus)
after that, set your OC for the card thats crashing to very conservative mem clocks. make sure youre using locked core clokcs for everything newer than 10 series.
