Hi there,
Hoping for some help here.
I’ve recently (as of 3 weeks) setup a new 12 Gpu rig - fortunately until today, all has gone well.
Literally out of nowhere, my xfx 6700xt crashed and I can see a log of a reboot. On the first reboot, I stopped all miners and reverted the affected Gpu to stock OC settings. I then rebooted again, suddenly only 11 gpus are detected and the affected card seems to have vanished.
I then updated the hiveos version, tested - same
Problem.
I reverted back again - same problem.
I’ve removed the affected card, then changed the settings in hiveos to 11 gpus - booted then shut down. Then changed back to 12 gpus for a fresh added card. - same problem.
Unfortunately, this particular card is too big to test individually in my pc. (Small itx case)
Is there anything else I can do before I potentially return this card?
I’m running a octominer x12 ultra which is a riserless case with 12 motherboard pci-e slots- I’ve swapped the affected card pci-e slot with a confirmed working card and tested, everything worked fine so it can’t be a faulty slot. This also confirms that the power pins are functional.
Additionally, I’ve been using TRM - would changing algos fix this? Seems like a stupid question, but I’m super stuck!
Many thanks.
