Hi, I’m not using Gminer, i’m using MiniZ
Try using Gminer or NBminer! Any of them will give you more MH/s, just say with Gminer you get better consumption, temperature and smaller feeds!
Hello
Still 26mhs on a ASUS GeForce RTX 3060 12 GB in gminer2.68 any sugestions ?
without any Extra config arguments
In MiniZ 1.8y4 i reach 33mhs
with --mode=80
Thx
Is it a 3060 LHR1 or LHR2?
I unfortunately do not have a LHR2 card yet to test with, but i would suggest hooking the psu up to a killOwhatt meter and check the actual wattage draw from wall, i believe that its not fluctuating the actual power draw but rather the ‘reported reading’ to fool the LHR mechanism imo.
Would like to get my hands on one tho and test.
Thank you!
I checked from the wall, its fluctuating 830W-1050W my whole rigg, on NB Miner constant 1050W.
What are your settings in Hive for CC, Mem, and power?
Can I have your settings? Thanks
hola, consulta y que drive tenes?
