Gigabyte H110 problem :(
my Gigabyte H110 motherbard does not run with more than 4 GPUS
it works fine only with 4 gpus
if i add the 5th gpu .it does not even boot to the bios
and it keeps rebooting
please help
do you have all the mining optimal bios settings set? 4g encoding/pcie gen/csm etc?
yes
4g encoding : enabled
gen 2
csm disabled
it has not minnig mood in bios
do u think i have to update the bios ???
If you’re not on the latest version of everything that’s a good place to start
