if i try something to change like i found here in forum, i will not increase, only decrease the values. do you have any idea?
thx markus
thx markus
you need to finish setting OCs. and your one 5700xt is thermal throttling, turn the fan speed up.
Hi thx for your answer. I already tried it, but changed back because the hash rate goes down…
thx markus
Proper ocs won’t make the hashrate go down. No oc = bad oc. Did you increase the fan speed on the one that’s at 106c mem temp?
