Hello
I’m mining using t-rex to hiveon pool with only 1 GPU : NVIDIA geforce rtx3060
Just added another GPU : AMD radeon rx6600
The Radeon was not mining anything so I supposed it was because using t-rex
Changed the flight sheet to use PhoenixMiner instead.
Still the Radeon does not seem to mine anything.
I can see up and running it in the console, with temperature but using only 3 watts.
And I missing something?
Or is it simply impossible to mix AMD and NVIDIA on the same rig?
