trex miner, i have tried other miner seem trex miner is the best for my cards
Conseguiste? Estoy buscando lo mismo
Conseguiste??
Hello, I have Asus TUF RTX2060 6gb with Micron memory. I set this settings for ETH with Ethminer
31.21MH/s
87W
Temp is 57°C
Clock 1000
Memory 1750
PL 125
Fan 60%
Can you advise me to change something or do you think this is a good setting for RTX2060 with micron memory.
Thanks and greetings from Serbia
You do bios mod? what bios you are using?
you have to choose nicehash pool⌠i think it doesnât depend on memory. samsung GDDR6 gives same resulst as others⌠follow my guideâŚ
- You need to copy your nicehash btc wallet address
- Create nicehash btc wallet on hiveos.( i hope you will do good. so i didnât give u detailed guide)
- Create new flightsheed on hiveos : Coin > OctopusâŚWallet > Nicehash btc walletâŚPool> NicehashâŚMiner> T rex⌠Thatâs it ma boy! Reply with your result. Goodluck!
I donât even know what is biosâŚ
I just bought my gpus. read my instruction above. replied to core2extreme.
2060 doing 37MH/s on ETH? Haha Ok bro
I get stable 33 MHs wit following settings:
1050 core
2200 mem
125 power
68 watts usage and 52° temp in an open case. Mines beautifully and quiet.
Hope this helps
2060 Hynix:
I use Core 1100, Mem -1004 , PL 85 = 329kh/w
Or hard one: Core 1100, Mem 2200, PL 125 = 357kh/w
Hi!
With these setting, did you get Mh for Hynix Vr card?
Uptime?
I donât think it would be stable in the long runâŚ
I use t-rex with Gigabyte RTX 2060 OC Samsung Memory⌠uptime 42 days without error.
I think this is the best overclock⌠or not?
