Senhores,
Tenho acompanhado o forum da HiveOS, mas nunca compartilhei nada. Sobre as memórias Micron nas GTX 1660 Super, vejo muita gente dando cabeçadas e minerando com Hashrate menor que as placas conseguem dar.
Uso um overclock estĂĄvel, estou usando a 3 meses sem problema algum. Vou compartilhar com vocĂȘs.
This is not my setup.
try
CC: 1050
MC: 2100
PL: 0
-350 / 1800/ 80W = 31,20MH is good
-350 /1845/80W = 31,24MH +/-
merhaba tek fanlı asus 1660s için oc ayarı verebilirmisiniz rica etsem
merhaba memory brandiniz ne ?
Mikron
core 1050 mem 2200 hiveos
zotac 1660 super ⊠1010 core 1600 memâŠ(30.91 trex). if i push more⊠will crashâŠ
Those micron ASUS need CORE at 1200. Lower/Higher clock - hash goes down. Try it. For memory you doing good, I have one card running at 1200-2699
mine has a bit different bios, but try 1200 clock and see if hash goes up.
Bro, you have all hynix, why donât you bios mod those?!?!
You can gain 4mh each
I was not aware I can. Do you know tuturial or yt link with explanation? I will try find by myself too.
Here you can find the noises to download and inside the thread you can even find the Son of a Tech video describing the mechanism.
I suggest you to start from the Palit bios despite to the Msi one, even if you have msi card
those are samsung cards with newest bios⊠dont use that .28 bios or you will brick the cardsâŠ
hiveos is reading bad the memory
1050 core 2200 mem is enough on those cards to get 32.50âŠ
Your 1660s can get 31MH, but mine max 28MH. Mine is Hynix Ram and I follow your setting -250 -1004 85
Any idea why mine only max 28MH?
930 core and -1004 ram if card aint with palit biosâŠ
Finding that 1050 core and 1800-1850 mem is as much as I can push before getting a driver error. That typically means the mem is software limited. Specifically, these are micron ASUS 1660S. Anyone know the hard limit of the top? I see some people pushing 1900 on micronâŠI donât think thats software supported so a little suspicious of those numbers.
