Hello. For my part, I have not succeeded in stabilizing it. So, I’m going to try the oc you suggest. I’ll tell you what happens. Thanks for your feedback
When I set Powerlimit to 140!
The System has no problem.
The Gainward is very sensitive with the settings. the other 3060 TI run with me with the settings. slightly throttled by the power limit. Without power limit it goes over 61 !!!
When you use this settings, experiment with the power limit so that the GPUs don’t get overheated as much.
Sorry I used Gminer.
Your core clock is higher than needed, which just wastes power and creates more heat.
Hi, wich core clock is better for the same hashrate and what for powerlimit?
You write higher than needed. Can you tell the right data.?
The goal is to find the lowest locked core clock that maintains full hashrate. If you can lower it 15mhz and hashrate doesn’t drop, you’re higher than needed
