Hi!
I just replaced my gpu 8 thermal pads and its turned on perfectly after few hours I got this message and i tried to reboot but its not working. I tried to place it to my pc and it gives no signal to screen is my gpu dead or what? I need help!
worth pulling it back apart and making sure theres even contact on the die, and everything is plugged in properly. verify the power cables and all are plugged in, riser is known working etc
