After a motherboard crash I have replaced it and made a fresh install downloading the “Beta Image” from HiveOS.
Previously the miners were running just fine and I could apply tweaks to voltage, memory and core mhz through the HiveOS platform.
Now the miner is running fine with the default scheme under the “overclocking” tab, but when I try to make changes and apply tweaks the miner stops working (the same as when using “shutdown”, fans are running but the miner stops mining and lists as offline on HiveOS platform).
It is not crashing due to overclocking too hard, it even happens when reducing mhz settings below the ones already working fine.
Anyone experienced similar problems ?
