Flash drive / USB not found by rig
I have formated the flash/USB-drive and then flashed the HiveOS to it (with different tools HDD Raw Copy and also Etcher). But when I connect it to my miner it wont start from the flash drive, and when I enter BIOS it doesn’t show up no matter which port I plug it into.
What have I done wrong? Have I forgotten to do something to the Flash drive, or is there some special setting in BIOS I need to modify?
Ah, finally I found the solution. I needed to enable CSM in BIOS
