Hello Fellow miners !
I am pretty new to the HiveOS mining Software and I have a couple of questions:
As you can see Im running 3 Sapphire RX 6800 (one is running in very low Hashrate). I tried it with the same settings as the other two, however it wont go past 57 Mhs.
The other cards can get up to 63-64 Mhs, however I cant find proper settings to do so.
If you would please check GPU 2. Its running high temperature with 75% of Fan usage.
The model of the car is Gigabyte RX 6800 XT Aorus. Could anyone tell me if they have the same card and issue with it, or maybe a fix for it, because I find it very, very odd that the other cards are running on similar heat/usage of fans and heat, and then there is this one which is on the brink of Overheating with 75% of fan usage …
Any information is appreciated.
Thank you
