Hi
I’m wondering if anyone has been able to fix the FE 3090 issue where the fan speed drops off to 0% after awhile hashing. I know my fan speed setting is working, as the card does not throttle, and the miner I use does not crash either. I just wouldn’t mind fixing the issue if anyone has figured it out.
J’ai le même problème…
