Hello, and good morning all;
I am curious if anyone else has experienced this issue that I am currently having. I’ve benched marked my card with Haven and a few others and it seems to be working as it should. But once I put in line on my mining rig it drops down to 92 Watts and will only do like 11.7 mhs on eth for example under Linux. And I am un-able to push it higher from what I can see. Under windows I am able to raise the power to 117% under master and get closer to 30 Mhs. I just for the life of me can’t figure it out, has anyone else experienced this? I would love to be able to use the full potential of my card.
Also under HIVEOS is there a command or something I can use to force the card to operate at a higher Wattage rather then reduce it’s power consumption?
Also running on Asus B250 Mining Board. Pretty sure the bios is 1206.
Thanks for any responses.
