Error message creating flight sheet for eth + ton dual mining: selected algo2 is invalid
Hi everyone,
I’m trying dual mining for the first time, when I try to create my flight sheet for eth + ton dual mining, I get the following message:
“The given data was invalid: selescted algo2 is invalid”.
Any thoughts?
click setup miner config, and make sure the fields are filled. Probably the second algorithm is empty. Hive doesn’t always selects it
Thanks man, sucess!
