HiveOS on ASRock h110 mobo mines 24/7 without issue No clock settings of any kind ETH…HiveOn
t-rex exited (exitcode=1), waiting to cooldown a bit
Skipping miner log rotation due to execution time < 30sec
20220206 14:17:35 ERROR: Can’t start T-Rex, can’t initialize CUDA engine, cuda exception: CUDA_ERROR_NO_DEVICE. Is NVIDIA driver installed?
20220206 14:17:35 T-Rex finished.
00:02.0 HD Graphics 630
0 02:00.0 GA106 [GeForce RTX 3060 LHR] <— The failing card
1 03:00.0 GeForce RTX 3060 (12053 MB, 170 W, Unknown) <—Also New that day and Worked perfectly
Tried:
Swapping risers, the other card mined both fine
Installed gpu0 to mobo directly
Mining only one card on mobo and two different proven risers
On stock hive driver 470.74?, then updated to latest 220205, rolled back to 470.74
Tried mining RVN
Gminer also would not start, with a fatal error I did not record as it was similar in nature.
