Dynex DNX Mining
This was rthe problem, I needed to upgrade the GPU’s drivers, everything is working fine now.
lol, good going. Thought of getting a k80, but was concerned not being supported by newer drivers
Keaton
If an exchange address is used, should I append the paymentID using the “+” after the address?
Don’t mine to an exchange, I don’t believe it’s supported anymore anyway.
their wallet is a bit of a pain. The prebuilt binaries don’t work. You should be able to compile it for your computer.
As keaton said DON’T USE EXCHANGES. Not too keen on their online nor mobile wallets either.
Hey I was just wondering, dynex is super big on vram right? what if you get a workstation card that has 24gb of vram or more. does that work for dnx? (I know pretty much nothing about dynex)
Got it!
Thank you
What problem ? How to fix them ?
Are you sure you’re using a correct wallet address?
I had problem like that.
Using %WORKER_NAME% as pass the problem was solved
