I had been mining fine, but wanted to change my pool. Couldn’t get past the can’t restarting miner message in the terminal.
Even upgraded to 1.44 hoping this would fix the issue with lolminer.
After comparing the config that worked against the one that didn’t, the only difference was the number of pool addresses. Added a few more to the config that didn’t worked, and started minging
Wasn’t sure if the problem was unmineable. I tried another pool that should had worked, but didn’t.
This shouldn’t matter, but card 3 is an AMD and all others are nvidia
This one didn’t work
--algo ETHASH
--pool ethash.unmineable.com::3333
--user ADA:wallet.rig_1
--pass x
--worker rig_1
--dualmode TONDUAL
--dualpool https://next.ton-pool.com:
--dualuser wallet
--dualpass x
--dualpool https://next.ton-pool.club:
--dualuser wallet
--dualpass x
--devices 2,3,4
--apiport 44444
--timeprint 1 --shortstats 10 --longstats 60 --basecolor
This one magically started mining. Seems that there is a problem with the parsing
--algo ETHASH
--pool ethash.unmineable.com:3333
--pass x
--pool ethash-us.unmineable.com:3333
--pass x
--pool ethash-ca.unmineable.com:3333
--pass x
--worker rig_1
--dualmode TONDUAL
--dualuser wallet
--dualpass x
--dualuser wallet
--dualpass x
--devices 2,3,4
--apiport 44444
