Dual Mining Ethereum (ETH) and TONCOIN (TON) issue after remove
Hello everybody.
I did an experiment with Dual Mining Ethereum (ETH) and TONCOIN (TON).
now i removed the flight sheet with dual mining (in lolminer) and left only one flight sheet for ethereum (in t-rex miner).
the problem that led me to open this topic is because in overview it continues to appear to select the charts for ETH and SHA256-TON.
how can i remove SHA256-TON from overview?
my apologies for the english.
try switching flight sheets to something else, then switch back. if that doesnt solve it, log out of hiveos, clear your browser cache and log back in
Hi.
It didn’t work, the solution was to remove the worker and create a new worker for the same rig.
However thanks for the reply
