Does low VDD cause a problem?
Hi, if I consider VDD instead of 850, 750, less power is consumed. Will this cause a problem for my graphics card (RX-580)?
The goal is to run the lowest voltage while maintaining stability.
Thanks, yes, I tested for a few days, I did not have a problem with instability. I’m just afraid that my graphics card will be damaged.
As long as it’s stable you should be good
