[quote=“altinsoft;513”]Great Topic ! Thank you 2FAN.
We live the same problem. Hiveos panel and OS are not compatible. Card sorting is incorrect. For this reason, OC settings can not be configured correctly. Examine the image file. Everything is in the middle. We are waiting for help.
https://forum.hiveos.farm/uploads/editor/nc/qzrjodn5jyyf.png[/quote]
AMD card number ordering may drive you crazy.
There’s some troubles with some old motherboards, AMD drivers and other hardware (ex. pci-e hubs - if you use them).
For example.
I have old 775 socket mobo ASUS P5QL-E and six RX560.
HiveOS panel and Claymore’s Dual miner says
card 0 = GPU0 and PCI bus slot 1, card 1 = GPU1 and PCI bus slot 5, card 2 = GPU2 and PCI bus slot 6 and so on on increment manner up to card 5 = GPU5 and PCI bus slot 9.
But on real life everything is much more complicated.
Only first card which in PCI-E x16 slot has correct number and the others go in a chaotic manner (ie card 1 has bus slot number 9, card 2 has bus slot number 5).
Thus, the mechanism for determining the mapping AMD based cards on the bus must be reworked. But I’m not sure that the mininig software do it correctly.
