Difference Between Expected Earnings in WhatToMine and HiveOS
I’ve noticed a significant difference between the daily earnings estimated on WhatToMine and the actual earnings shown in HiveOS for my mining setup.
In WhatToMine, the estimated daily earnings for my GPU are higher than what HiveOS reports under similar conditions. I’ve checked my hashrate
What coin/pool/gpu? And what is your hashrate?
Thank you for your quick reply. Here are the details of my setup:
Coin: Ravencoin (RVN)
Pool: Hiveon Pool
GPU Mix: GTX 1660 Super, GTX 1660 Ti, and RTX 3090
Hashrate: 457.4 MH/s (combined)
is the 457mh represented as the 24hr average on the pool? How long have you been mining on the pool?
Theo HiveOn "Est. daily earnings” value is directly related to the 24h average hashrate value. Therefore, the estimated reward value will be close to real after mining for 12h uninterruptedly.
I apologize for not knowing about the 24-hour average hashrate representation. I have mined on the pool for about 4 to 6 hours and then turned off my machines due to the hot weather. I didn’t want my hardware to overheat.
Thank you both for your detailed responses. I now understand that the “Est. daily earnings” value is related to the 24-hour average hashrate.
I appreciate your support and assistance.
thanks :slight_smile:
