Great that is it runs in something
If I remember correctly, you should be under clocking the core in Windows and maxing out the memory freq. Not sure if current Radeon drivers make a difference, all my 6800’s are in Hive since the f-state scripts were put out there this summer.
In radeon software try
1100min-1200max Core
2148-2150 Memory
Should be able to back core voltage under 793mV
I’d leave the fans max if there is any suspected cooling.
Save to Radeon Profile at each stage that is stable as you work toward it.
You should be able to load a fresh BIOS in that slot from Hive or Windows with the right settings/tools.
