Anyone else having issues connecting this morning ?
I have the same issue
i just did the latest update right before , as well…
Something went wrong
No need for panic, though! The mining process isn’t affected. Please let us know about this issue - we will fix it as soon as possible.
Error details: 12-05-2021 07:48:44 -07:00 -863689467-
yet now my miners are not connecting …
that are no longer mining
Ya, it’s something to do with the update. I tried to roll back to older OS versions and that didn’t seem to work either. I also update my GPU drivers cause they were super old that didn’t work either. I have 4 RTX 3080s and it’s only mining on 3. It sees the other one but won’t mine on it.
fortunately I created a backup boot drive… 2 days ago…
now attempting to boot from it and see if I can at least get mining again
im back to mining.PRE UPDATE. tho , no user interface , and no access to the shell via browser.
I have done some more digging and found that Hive OS is down. People are suspecting DDOS. Right now there is nothing you can do. The ball is in Hive OS court.
Error 502
Ray ID: 64e4a2d34e0eeb31 • 2021-05-12 15:21:18 UTC
