у меня к сожалению нет доступа к ригам по ssh или как то еще, чтобы грамотно установить майнер energi. хотелось бы просто выбрать нужный майнер в списке майнеров в хайвос и чтоб он майнил монету NRG - будет ли такое реализовано на хайве?
I have installied the energi miner. But i become this error message from the Pool back.
Worker not authorized:
I have used the Wallet Adress.rigname
for example xxxxx.amdrig
Can anyone help
Need help. Can’t run any custom miner(on ver 0.6-07)
I tried lots of custom miners(including from this topic). Also I used this manual - https://medium.com/hiveon/getting-started-with-hive-os-adding-a-custom-miner-b13abff421ae
Whatever I do I can’t see any reaction from hiveOS. No messages, no errors, no additional files in dirs, no changes in configs.
Where should I look at to see what is going on inside ? Just to see what I’m doing wrong.
In additional to this. What is custom-get command ? Should it be used in hiveOS inside console ? Because I got the error “bash: custom-get: command not found” there all the time.
Привет, добавьте пожалуйста в hive https://github.com/technobyl/CryptoDredge/releases/tag/v0.15.1
пока скорость хорошая.
Пишите в личку кому нужен рабочий https://github.com/technobyl/CryptoDredge/releases/tag/v0.15.1 в хайве
Hi there, i just try implement the https://builds.beam.mw/mainnet/2019.01.03/Release/linux/cuda-miner.tar.gz via the custom miner function on hive. but i always get errors. i guess the miner is not compatible. is this correct?
Thanks sterling!
 will try it today
Hi Sterling, can i use RX570’s with this miner?
No, it’s only for Nvidia cards.
But there will be Beam OpenCL Miner in next HiveOS update.
Thanks for the link. This helped me get up and running with 3 x GTX1050Ti on my rig. Not sure why yet but my other 2 x GTX 970’s are just idle and not mining !!! Any help would be appreciated if anyone knows.
4 GB are minimum for equihash 150/5
I can’t seem to use the bminer 11.2.0 release. I can’t get it to work. Maybe I’m doing something wrong in the flightsheet setup for beam.
I thought both RX-570’s and GTX-970’s had the minimum 4GB for equihash 150/5!!
Подскажите пожалуйста - как сделать чтобы заработал этот майнер https://github.com/EggPool/EggMinerGpu/releases/tag/4.0.100 для монеты BIS - и какие правильные параметры пула http://eggpool.net нужно прописывать?
Или подскажите как его загрузить в Hiveos
