Добавьте пожалуйста новый майнер JCE Cryptonote CPU+GPU Miner :
https://bitcointalk.org/index.php?topic=3281187.0
https://github.com/jceminer/cn_cpu_miner/raw/master/jce_cn_cpu_miner.linux.033e.zip
I’ve just tried this and unfortunately only CPU is supported on the Linux version. Windows version. We have to wait until the devs release the Linux version that supports GPU mining.
Edit: The windows version offers about 10% more hashrate than the alternatives…
Подскажите, как добавить алгоритм VERUS?
Когда разрабы соберут пакет кастома специально для хайва GMiner CUDA Equihash 144,5/192,7 Miner v1.07 https://bitcointalk.org/index.php?topic=5034735.60
Please update GMiner CUDA Equihash 144,5/192,7 Miner v1.07 https://bitcointalk.org/index.php?topic=5034735.60
Energi Stratum support added to the miner, now pools are available http://nrg.minecrypto.pro/getting_started. Experimentally added support for Hiveos:
https://github.com/GRinvest/energiminer/tree/master/HiveOs. To run the miner is required library libstdc++6. If not installed, install with the command:
add-apt-repository ppa:ubuntu-toolchain-r/test
apt-get update
apt-get install gcc-4.9
apt-get upgrade libstdc++6
Farm hashrate may not show
On the pool website, the same link for Linux and hiveos
Thanks, Huge advance!
please do GMiner CUDA Equihash 144_5/192_7 Miner v1.08 https://bitcointalk.org/index.php?topic=5034735.msg45995175#msg45995175
BTG = 87 sol/s !!! (1080ti)
Miners updates currently delayed until client 0.6-01 will be released.
Sorry for inconvenience.
Could you please, at least put the new distributive in you ./custom folder.
We already have 2.4 in your folder 2.2.2
PASC hardfork is coming!
You should add appropriate tool (hint: FinMiner 2.4)
Updated
Will we be able to also run the cpu mining on finminer for the new randomhash for pasc
How to set up FinMiner for PASC
Made a video of how to run the miner energi (NRG) on hive:
