Create First Flight Sheet No Hash Rate
yep, same as reflashing the drive, no need to replace the config file with hive-replace too. just does a clean fresh install
So I been mining XMR for a week now. It says on there site that Monero’s block reward is currently around 0.6 XMR every two minutes. I am using a XMR wallet from Account Information | xmrwallet. I have checked the address of the wallet and it is correct. But I have no balance
It does seem to be mining so any idea what might be wrong
one cpu at around 7kh will take a few weeks to reach a min payout most likely, will vary based on the pool you chose and what you have your min payout set to.
Yea I went to the pool it is adding up, I am putting a CPU unit online today with same Sheet
