Cpuminer missing zen2 and zen3 binaries and dependency problems
I just started using cpuminer on hiveos and noticed that the amd optimized zen2 and zen3 binaries are missing. I tried downloading them manually from cpuminer releases (same version 1.1.9) and replacing the binary started in the script h-run.sh. Whenever I try starting it I get the following error:
./cpuminer-zen2: /usr/lib/x86_64-linux-gnu/libcurl-compat.so.3.0.0: version CURL_OPENSSL_4’ not found (required by ./cpuminer-zen2)`
I am using the latest version 0.6-210@210928
How to fix that?
Update:
I tried running the binary manually and it works with no problems. So it must be a problem in the hiveos pipeline and how it sets the environment. Can anybody help?
Would this help?
(Im on same spot, just with /usr/lib/x86_64-linux-gnu/libcurl.so.4: version CURL_OPENSSL_3’ not found`)
did u find a solution?
