I’ve been trying to find out how to enable power consumption. It only shows for my GPU but not for CPU mining RIG. Here is a picture
There Isn’t an accurate way to measure system power (cpu/ram/chipset/fans etc) via software, though you can measure your power at the wall with a kill-a-watt or smart meter, then in the settings enter in the power draw for that system which will let you keep track of usage/costs.
got it because I have seen other YouTubers, and you can actually see the power consumption on it
