Hi guys, I have the following problem, the problem is with the gpu 4, how can you see all the gpus perfectly reach their power limit but the gpu 4 does not and I do not know why, what can it be ?, the power supply, risers, splitters? , is only that gpu, i used another miners and did not solve the problem
and incresing the oc, the gpu crashes
