I got those error bellow over, and over !
I configure my runsheet (epool.txt and userconfig) this way :
POOL: eth-us-east1.nanopool.org:9999, WALLET: %EWAL%/%WORKER_NAME%/%EMAIL%, PSW: x
and the config Override:
-ftime 10
-tstop 90
-tt 60
-cclock 1150
-mclock 2165
-cvddc 850
-mvddc 900
-fanmin 30
-etha 0
-mode 1
Also try to add my wallet number info, like in my BATCH File i run on my Windows miner… same issue…
nothing seem to work. I only try 1 GPU from my Windows miner… I will put it back until figuring out how to make it work !
����������������������������������������������������������������ͻ
� Claymore’s Dual GPU Miner - v15.0 �
� ETH + DCR/SIA/LBC/PASC/BLAKE2S/KECCAK �
����������������������������������������������������������������ͼ
no address specified - ignore
This pool (eth-us-east1.nanopool.org) does not support Ethereum addresses as login (or requires worker name in “Login.Worker” format) and cannot be used for devfee mining, there
fore it is not supported.
However, you can mine on this pool if you specify “-allpools 1” option, default pools (different from this pool) will be used for devfee.
Please read “Readme” file for details.This pool (eth-us-east1.nanopool.org) does not support Ethereum addresses as login (or requires worker name in “Login.Worker” format) and c
annot be used for devfee mining, therefore it is not supported.
Please read “Readme” file for details.Pool eth-us-east1.nanopool.org removed from the list
ETH: No pools specified! Specify at least one valid pool in “-epool” parameter.
claymore exited, waiting to cooldown a bit
