Complete power shut down required after configuration change
I’ve had issues that after a configuration change, the cards don’t mine. Only way to solve this issue is to cycle my power supply on and off. I thought the new feature of “shutdown and reboot after 30 secs” would fix the problem but it persists. Is this some ram issue that persists?
An answer please ?
No answer, ccminer requires me to pull the plug (literally) after updating.
I just started having that problem too.
i’ve been using my smart plugs if i’m not nearby so no big deal, just use my phone to power cycle. You’ll have to change bios settings to ignore the power button though
