I am currently mining Zencash with DSTM (NVIDIA) getting around 670 sols and when I enable the 2nd Miner (Claymore Dual Miner) using only my AMD cards, my speeds lower for both miners 530 sols.
Any Ideas?
Any Ideas?
I think this is due to the Nvidia GPU0 card being used for both miners, I tried to use the “-di 1” command in Claymore’s to just have it use the AMD card but it does not seem to work.
Any Ideas?
I figured it out, I had to set it to -di 0 even though the AMD card was registering as GPU1
Hi. when its planned the miners update actually we have a Claymore dual 10.1
Can anyone tell me how to set the claymore zcash wallet to mine zencash? I have tried and i am getting an error saying “ZEC: authorization failed” and i am not use what is going on with this.
Can anyone tell me how to setup the claymore zcash wallet to mine zencash?
I am getting an error saying ZEC: authorization failed when trying to use this miner.
