Ошибка claymore: DPOOLS_TPL or DCOIN is not set, clearing dpools.txt and setting "-mode 1"
Не запускается майнер claymore 15, ошибка: DPOOLS_TPL or DCOIN is not set, clearing dpools.txt and setting “-mode 1” и красным No adress specified-ignore. Подскажите, пожалуйста, что делать
может дело не в этом: дальше лог
ETH: 2 pools are specified
Main Ethereum pool is eu-eth.hiveon.net:4444
At least 16 GB of Virtual Memory is required for multi-GPU systems
Make sure you defined GPU_MAX_ALLOC_PERCENT 100
Be careful with overclocking, use default clocks for first tests
Press “s” for current statistics, “0”…“9” to turn on/off cards, “r” to reload pools, “e” or “d” to select current pool, “x” to select GPU, “z” to find best -dcri values
OpenCL initializing…
AMD ADL library not found.
^CMiner: claymore
Version: 15.0
Creating epools.txt
Appending user config
ethdcrminer64 is already running
Miner screen is not running
