Changelog HiveOS 0.5-75 says "...is required for claymore nofee hack"
In the changelog of HiveOS 0.5-75 there is a point with
IMPORTANT: default setting in claymore is “-allpools 0” now,maybe you will need to add “-allpools 1” to user config in Flightsheet if you use non-ETH pool.
This can improve stability and is required for claymore nofee hack.
What does this mean? Does HiveOS have a nofee hack or does it mean the “-nofee 1” argument in the command line?
HiveOS doesn’t have a nofee hack. it was wrong feature description.
