Ccminer error Need help setting up
Hi there
I’m new to mining and trying to get my first rig going with Hive OS.
I have the machine setup running Hive OS and I have assigned it a flight sheet.
When running I get the following error if anyone can help please that would be great
./ccminer: error while loading shared libraries: libcudart.so.9.2: cannot open shared object file: No such file or directory
ccminer exited (exitcode=0), wiating to cooldown a bit
I’ve seen a few similar threads online explaining that this is a nvidia driver issue but I don’t know how to resolve this within Hive OS.
what coin are you attempting to mine and what image/kernel/driver are you on?
Hi Keaton
Thanks for getting back to me
I’m trying it out with Dogecoin to start this is what I’m running:
OS Version 0.6-229@241231
A 5.6.1 (6.8.2411.0)
N 550.142
Drivers
Kernel 6.6.0-hiveos #60
My machine has 1x M4000 and 3x P5000s Quadros
Dogecoin is only worth mining with ASICs for the last 8+ years or so, if you can find a miner that still supports scrypt on gpu, keep in mind it will earn nothing at all as 1 modern asic is equivalent to thousands of gpus on that algo.
Check hashrate.no or other profit calc type sites for coins that may make sense to mine with your gpus,
I see I forgot to look into this with dogecoin
Is this what would be causing the error I’ve been having?
Not specifically, more so that the miner is obsolete.
