I need to move a card to my other rig due to space after buying another card. It is working/mining on two different windows machines but when I try to put it on my hive based machine it will see the card as a 6700xt, with x’s for the serial number and no temp/fan/voltage info, and wont try to mine. I have tried adding it in addition to the existing cards already on there and also replacing a working card (riser, power connectors, mobo slot etc) so I believe its software based not hardware
I am using pheonix miner set to latest version, os version 0.6-213@220107
TB250-BTC PRO BIOSTAR Group (5.12 06/07/2017)
4 × Intel(R) Core™ i5-6500 CPU @ 3.20GHz AES
Disk Model ATA SPCC Solid State 256GB, ATA WDC WDS120G1G0A- 120GB
System type linux Kernel 5.4.0-hiveos #99
I’m a beginner linux/hive user so I don’t know if people need more info to diagnose? I also setup this system right as the 6700’s were being released, so I don’t know if there is something that running the update command didn’t catch that might keep it from working
Thanks for the help!
