Hello , I added to my rig sapphire rx 590 and hiveos see that card but not mining there is a X look at image
its offline, looks like you have bios flashing going on. Did the system found gpu after flash was completed /reboot?
hi I cant change anything , it doesnt flashing now i tried to turn on windows and change bios bg atiflash
okay, i thought that you are on linux. Did you attached card straight to mb and go from there?
Its connect by riser
okay, your not sharing too much info
…good luck
It is connect by PSU and riser is connect diffrent cabel from psu
