Try removing or upping the power limit
Hi, Thanks for the reply. I have not put any PL as it is auto controlled by the limiting core, i believe.
Right now they are currently blank
you have 130 powerlimit set in the picture and you can see its limiting at 130w
30mh is right where you should be
I would try lowering the memory on that card and rebooting.
