Can not connect using VNC?
Is there any specific configuration to connect to a local rig using VNC?
I have 2 rigs.
I can connect to the first one using VNC.
But I don’t know why, I can not connect to my second RIG using VNC (while a ssh session with Putty is working fine.)
Any clue?
Thank you in advance,
mttmining
I ended up installing the vncserver so I could get my vnc client to work. On the nonworking box after ssh into it run
sudo apt-get install vnc4server
next run
vncserver
it will prompt you to set a password (at least 6 characters long)
then from your vnc client for the address put in the ip of the rig with a colon 1 (example 192.168.1.34:1)
it will then prompt you for your password that you entered above.
