Can i use Hiveon Firmware on my l3+ without using hiveos?
Hey! i want to use hiveon firmware on my l3+ so that i can use the power profile and auto tuning features but i dont want to be forced to use hive os to connect to a pool. i plan to just connect my l3+ to nicehash via the scrypt pool on their site. do i have to use hive os and its weird flight sheet system to do that? i don’t really want to.
any insight is appreciated
youre not forced to use hiveos to monitor and manage it, but youre missing out on push notifications, ability to remotely check on temps, remotely make changes without the need of Remote Desktop and copying pools/addresses and pasting them in the ip dashboard. You can set it and forget it if youd like just like stock fw.
cool so i can just set a pool in the firmware and i don’t have to use a flight sheet?
Yeah, nor do you need to use a flight sheet to monitor in hiveos either. Flight sheets just make it easier to make changes to the coin/pool/wallet in use. You can always set your pool and wallet the traditional way, its just more of a pain to change it remotely.
awesome thanks for the info
