Hi! Check that the card is supported by HiveOS. Try using the newest version of HiveOS as it gives support for more GPU’s
If you use the command helpme you will se there is separate commands for upgrading the GPU drivers to the last version. You can use that to load the latest version og the GPU drivers. It might help.
I believe the kernal error you are seeing is due to Linux trying to load the linux kernal image, but cannot. It is a strange message.
You could also try downloading the HiveOs latest image and make a fresh USB. Then load the HiveOs without any config and similar. To eliminate config issues…
