hello, I have a rig of 6 AMD RX 6600 cards (not XT), currently I use the default settings: core clock 950; memory clock 930 and core voltage 625. Memory voltage and memory control voltage I don’t have them set.
Currently I get 28.2MH/s per card and 50W of power consumption.
The fans are on 10% fixed, with a temperature of 50°C fixed.
Do you think it’s a good setting or you could do better, especially to preserve the GPU over time?
Hi @Tony4L, there is a very detailed thread on the RX 6600 here;
It should give you all the information you need
