i think you are wrong
Ergo needs mem clock rather than core clock !!
i’ve set the mem clock to 1800 and the hash rate dropped significantly to 53mh and 45mh
Forgot to add that mine are bios modded
thank you coatercup !!
here are my settings after i did same OC as yours :
i assume that mine is also bios modded because i bought it used .
is there any specific way to know ?
Its modded. His cards are obviously different.
I do 60 with 1168 core 850 voltage and 2000 mem clock
Download your bios in HiveOS
Patch it with this:
Flash your bios in HiveOS
Google the risks and take precautions. Enjoy…
Hey thnx for the tips here, I have a RIG with 3x rx 580 4gb (2 asus and 1 xfx) 2x rx 480 (4gb xfx) and 1 rx 470 gb xfx. you think its good to apply the above mentioned settings?
Actually for the 4gb cards i am not sure if you can go above 2000 memory clock. But you can try
I run a mod bios with the settings below and get a hair over 71mhs per 580 card. I also use TRM
71.14mhs @ 104 watts.
Core 1325
Core mv 1040
Core index 1
Mem between 2090-2100
Memory controller mv 850
Memory index 1
amdmemtweak --ref30
This is so good… how you got so much HR… can I see your setting.
This my OC setting… I’ll appreciate your any suggestions… Thank you so much. greeting from Indonesia.
The other miner is not mining ETC, his 580 4GBs are mining ERG:
