I have checked on there is no help from the support manual that helps my own version of B250 Mobo is E13594
YES - probably work with just A1.
Run the same SATA power cord to A1, A2, and A3 to be safe.
These three all have to be powered by the same PSU or the magic smoke will escape!
Thanks for the response, I will share what i have connected once I close from work . Also from your suggestion do you mean the 4-pin AUX Connector becuase I have connected the 8-pin connector and the 24-pin Connector since i am not running the whole 19 gpus
