Auto fan error xserver not running
Hello there, i have 2 workers, this afternoon both of them had the same error "auto fan error can’t set fan speed, xserver not running anyone have this problem? The thing is the both workers give the error at same time, the only solution I have found is to give command directly from the connected keyboard to worker hive-replace -y --stable I can’t find any other solution.
The question is: how can I run this command remotely, I’ve tried to send the comand form hiveos phone app and from computer but nothing happens… If I open shell in a box it ask me to login but the username and password are not accepted … Any solution to fix remotely?
Thank you.
