Asus RX5700 Problem
I got a RX5700 that i dont get any hashrate from is it broken or is something other wrong ?
What version of hiveos to use and is stable ?
Regards,
PaX
You need to use the beta version as this supports the Navi cards
Hello. Is there some change? Can new stable os version handle the mix of navi / polaris ? Or we still should remain on Beta ?
I’m having the same issue and went and downloaded the beta version and am still getting the same issue. Either 0 hash or 751kH. RX 5700xt cards. Gigabyte and micron mem, brand new out of box. I have 5 more to add to the rig but I want to get this problem solved before I do. Any ideas?? TIA
