Hello fellow miners, anyone here with a Asus Prime H470 Plus that managed to add more than 4 gpus, could you share your Bios settings?
I have some weird stuff going on, I already applied the most common Bios settings found on the web, however as soon as I add the 5th gpu, the power starts, but it doesn’t boot. I changed risers, PCI ports, gpus, adding one at a time, well almost everything, but no success, the behavior is always the same as soon as I add the 5th one.
And it gets weird, because if I connect a HDMI to the motherboard, I can only start with 3 gpus, as if the CPU motherboard counts as a limit…
I have a Gold G6500 CPU, 120GB SSD and 8BG RAM.
